ajcal225
Mar 24, 2014Explorer
When I got into the last corner, it was in a lot worse shape than the others. I've decided not to tackle it today, but will get into it next week sometime.
There's clearly been water here.. I found a bad anode on the water heater, so that isnt a huge surprise, although disappointing.
I'll have to tear that corner down a lot further and build some new structure. Its under the bathroom, I really don't want to be standing in the shower thinking about a half assed repair. :/
I picked up some PVC siding to cover up the areas missing fiberglass, and a couple of tubes of Dicor to seal things up with. It wont look perfect, but it should be water and wind tight
Once I get this done I'll load the thing up and head down to a friends shop. We'll build new jack mounts that run top to bottom in all four corners, and extend along the bottom edges of the camper so I can add better tie down points. I was really unhappy with the geometry of the tie downs when I brought this thing home.
