ajcal225
Mar 25, 2014Explorer
johnhealey1776 wrote:
After rebuilding those corners too,I would cover them in something like ice and water or vycor, then get some diamondplate aluminum bent up to gusset in the corners. Would probably look BA and add some strength.
I didn't think about that. That would be a lot cleaner than grafting pvc into the damaged areas, and it could be integrated into the jack mounts pretty easy. We'll be cutting the jack mounts on a cnc waterjet table, so its possible this could be made very sexy..
Too bad I can't tig aluminum, that would look way better than doing it in steel. You've got me thinking.. time to make some phone calls.
