ajcal225
Sep 15, 2014Explorer
I was worried about the white color, but it looks pretty good!
I ran a 3/8 bead of non leveling Dicor around the inside edge of each plate before mounting them. I've already had to clean Dicor off of my phone twice, so didn't take any photos until things were mounted up and I could wash my hands.
The longer pieces had warped some when cooling. We had to attach the bottom, run a long ratchet strap around the camper and suck them down.
You'll see not all holes are filled; I was running low on screws and Amazon hasn't delivered the last 2 boxes yet. I'll run those home later.
All assembled and cleaned. No jacks yet, i needed to cool off a bit.
A before and after of each piece.
AAAAND finally; this is what the all original undamaged corner looks like. I made a piece for this corner too, but its 104* outside so I'll install it later. My plate looks waay better.
I'll have to reinstall all of the trim and molding I removed, and cut/trim it to fit around the new plates.. but its turned out way nicer than I had ever hoped. Once I'm that far along I'll seal the outside edges of the plates with some ProFlex, as well as all of the windows access panels.
