ajcal225
Sep 29, 2014Explorer
First trip out with the camper was pretty successful!
The one corner that was 'undamaged' is coming apart under load of the tie downs, so I need to be careful unloading and tear into that one next, no big deal; I already made the brackets.
Grey water valve leaks all the time, black water valve drips just a little when its really hot out (105*) and the trap under the shower leaks. Gonna give it another day or two for the contents of the black water tank to break up a bit, go flush the tank really well and start tearing into the plumbing.
Obviously new valves on both sides. Since I'm pulling both valves and the trap for the shower, I'm going to find a way to redirect the shower drain over to the gray water tank.
What are thoughts on putting a valve in to also let me direct it to a hose bib for desert camping, and run the shower drain off behind my truck?
