AnEv942
Jun 29, 2014Nomad
Edit: responded and you posted fix.
Ours had simulaur issue. When gen was installed (by dealer), battery pre wire didnt reach. So they 'bolted' another piece of battery cable to end of pre wire cable. When I had starting problems I found this eye to eye bolt connection. Good greif. In looking for place to make a permanent connection I also found on the other side of panle where the originl pre wire poked thru an addtional 4' of cable coiled up. Instead of pulling the wire thru they added to it. Professionals...
