It says Destiny on one side and Royale on the other so probably not the best frame. I think it was probably an extended version of a trailer with a smaller bed on the front instead of our big queen without bothering with a stronger frame. I now recall that the frame did crack years ago. I welded it myself but it made little difference so I took it to the welding shop, and was told the frame seemed to be too week so much stronger steel C beams were welded underneath. It was never overloaded but certainly went on roads with potholes and I remember a bad rural railroad crossing thump. Sorry about not posting photos last night; it was dark when I got the idea to ask on rv.net.
The side with the door scarcely shows the immediate problem with the door bolt lock (usually there is a noticeable gap in the top right half of the door) - the jacks must now be compensating for the droop.
The back left shows the extra beam:
And so does the end view from back right.
This view from the back shows most of the beams and it seems to sag over a long length rather than in one spot.
Here is most of the right side.
