whizbang wrote:
Did you test your plumbing?
just the cold water portion. I didn't test any of the propane items yet. Everything else works good. pump (with new switch) works good. had to clean out the aerator.
Wife commented that the faucet in the camper is nicer than in her master bath :)
is the best way to empty the water tank to just open up the faucet and let the pump run it all out?
I've been going through the stickies here, and now have a decent tarp/awning to use. Whoever did the refurb on it, used eye bolts (assuming they aren't stock) to secure the top to the rood lift bars, so I can easily attach stuff there...
