burningman
Feb 19, 2020Explorer II
If you put wheels and tires on it that can take the weight, the rest of the truck will do it.
It’ll be slow. And if it’s an automatic (which I assume because you mentioned putting in a trans temp gauge), it may have a hard time ever getting going from a stop on a steep hill. If it’s 4WD then low range will save you.
This is from my experience with a Chevy with a 6.2 and Ford with a 6.9 automatic, which I once had to back down a hill against traffic the wrong way on a busy downtown Seattle street when it absolutely wouldn’t do anything trying to start on a hill but smoke the trans.
On the Chevy I solved the problem by yanking the diesel and putting in a Caddy 500, and even that once refused to back up on a steep hill loaded heavy with no low-range.
However I do have an ‘80s Chevy 4x4 crewcab dually, manual trans, that will walk up any hill under a huge load with just a stock and tired 454, because of gearing.
I think the auto trans is your biggest worry on your truck.
