kjenckes's avatar
kjenckes
1996 Ford F250 camper- Long post...
Good morning all. This post is to make a few observations and ask a few questions that I think a lot of folks could benefit from. I have read everything I can here and appreciate the thoughts and experiences of all. Mostly all. Please do not preach.
My current rig:
1996 Ford F250 7.3L Powerstroke diesel, crew cab, 4wd with the weird Ford "short bed" which is 7 feet. I have Supersprings added onto my leaf springs. These are the only mod I've done for the suspension. Happi-Jac tie downs.
2006 Northstar 850SC, rear bumper, AC, roof racks, 100W solar panel attached to the racks, roof ladder, 1 group 29 battery, full bath, electric jacks and camper is always loaded with gear ready to load up up and pull out. Camper is made for SB with storage boxes and lights. It fits perfect on the 7 foot bed. 8 1/2 feet long and 7 feet wide.
The truck settles 2 1/2 inches on the driver's side and 2 3/8 inches on the passenger's side when loaded. The truck handles this great. No sway, etc.
So.... here are the numbers:
Sticker:
8800 gvwr
4600 front axle rating
6084 rear axle rating (btw these are the numbers on the recommended tires, hmmm)
truck with it's normal load of stuff including fuel and my fat ass but no camper:
7084 gross
4240 front
2840 rear
This means that, by the sticker, I only have 1716# to max GVWR but 3244 to rear axle rating. Hmmm... Did I mention I have used this set up (towing a 20 foot bassboat frequently) with out an issue and the rear only dips 2.5 inches?
Weight with the camper:
9840 gross....1040 over
4220 front... pretty good COG if you think about the front being 20# lighter with the camper on.
5620 rear which is 464 below max axle rating. That would be closer with the boat.
This means my camper weight as loaded is 2760 dry. Granted I have pots and pans, food, microwave, clothes, etc but that weight surprised me a little for a soft side. Hard sides weigh in the same area.
I am looking for a different camper this winter. No I am not buying a new truck. This truck has 600,000 miles left on her. I want a hard side camper. I'm a common sense kind of guy as opposed to a strict sticker guy so I asked my son about the weight ratings. He is a school trained diesel mechanic and he asked his mentors. The question: How much over the stated rating is the true failure weight? We know these things are rated way under for liability concerns. Their answer: "You will never reach that weight. The tires will wear a little faster at some point above the rating but no catastrophic failure. The axles? Never" Not with out flattening the truck.
So let's look for better tires and wheels. 19.5 right? They do not make them to fit this style Ford. At least I can not find them on line nor can my tire shop. He can find me an E rated tire with a 3400# rating as compared to the typical 3042. He also said the tires will not fail me even over weight. My current weight is 464 under and this 800 extra would give me 1264# of cushion tire wise currently. Cool.
So campers. Before I weighed it and talked to my son and the tire guy I had been looking strictly at 8 1/2 footers to stay fairly close to the current weight. Now I am thinking maybe a 9 or 9 1/2 footer. Maybe even a 10 footer. The COG is pretty much a hard line for me though. There are several Lances (915 and a 1025) with the same COG as my 850 so I know weight distribution should be basically the same. The posted weights for a 10'3" Lance 1025 is 2370 dry and basic w/o options. Adding 800 # for the options and my stuff is only 430# more than my 8 1/2 footer.
So my thoughts are.... An extra 430# or even 1000# should be fine. I may at that point add Stable Loads though. Keeping in mind the COG for handling. I compared my truck to the same year F350.That F350 has a GVWR of only 400# more. That's ridiculous.
My questions:
Who here has a similar truck and ratings and a larger camper? Considering all of the weight arguments someone has to.
What are they?
What are your numbers?
What are your experiences and thoughts about your set up?
Did you do anything extra for suspension mods after buying a larger camper?
