A Host Bachelor is 8 1/2 and a single slide with not a lot of extra cabinetry.  I think that would be ok as long as the tires aren’t overloaded.  You will need to concern yourself with how much extra weight you carry and how much water you carry.  It will handle quite a bit different with full black/grey tanks, so dump before you travel.
Btw, I carried my 9 1/2 Double Slide on a 2006 F350 for 8 1/2 years.  It is quite a bit heavier.  I just got in the habit of carrying less water since it has 60 gallons of water when full.
Obviously, most DRWs have a lot more stability, but that model was made for SRWs.
