BTPO1
Mar 10, 2014Explorer
MartyW wrote:
Thanks Dr Quick,
I'd sure like to figure this out to do the correct way if possible. If I wire the brake in at the rear then as I understand the brake light will be hot while a blinker is also blinking and I'm guessing we would see the blinker as an intensified pulsing light since the brake light is already on (not lifted)?
If all of your lights are now working properly without the 7 pin connector, and the brake lights are not intensifying I don't see how hooking the green and yellow wires at the bulb will cause the brake lights to intensify. By adding those wires you are only adding an extension of what is there already.
As an afterthought have you checked all of the pins on the connector for proper operation. was helping a friend with his 5er a few weeks ago and the pins were rotated and not in the proper positions. Just a thought.
Related Content
- May 10, 2025Community Alumni
