tony_lee's avatar
tony_lee
1999 2500 10.6 Bigfoot camper replacement sink mixer
This unit is sitting down in Argentina and I'm in Colorado so I can't just pop out back to check things. No RV accessories stores down there either so I need to take bits and pieces down with me, or put up with it.
Kitchen sink mixer tap leaks a lot unless the tap handle is placed in precisely the right position and even then it still causes the pump to run occasionally.
Unit is 14 years old so it is a long shot, but does anyone know if a mixer repair kit is available. Failing that, or if a pain to pull apart and reassemble, is a complete new one still available? Or are these things standard enough that any single hole mixer tap should fit.
Guess since that is the only real problem I know about and everything else works OK, I haven't got much to complain about.
  • If you can't figure this out who the hell is hiring you? I need a job
  • Sorry pugslyyy, didn't see your post.
    Doubt whether I'll be able to get a better deal than you are offering. I'll send you a PM
    Thanks
  • Alternatively, a photo of the kitchen sink in that vintage bigfoot would at least let me pick up something similar.
    Thanks
    Is this the 8" on center single handle? If so I just pulled mine out to switch to a 2 handle model. I'll send you my take off if you pay for postage.
