ACZL
Jun 27, 2015Explorer
1st oil change = bath
Did my 1st oil change yesterday and when I pulled out the drain plug (not on bottom of pan, rather rear side corner), oil came shooting out like a rocket at me. Most of it I got in drain pan, but some landed on blacktop, creeper and me. Thank goodness is had cooled a lot. Let oil drain from pan till hardly anything and then loosened filter. Like w/ the drain plug, good thing I had the drain pan under it as well. Couldn't believe how much came from it as it ran down the filter. Let that drain till and while it almost stopped, put pan plug back in. Found a couple pieces of wood that straddled the pan and placed a wire screen I found in garage to place filter on (top down) so oil would drain out. Installed new filter.
Once complete underneath, time to add new oil. Need a step stool and of course, funnel doesn't fit 100% and not the easiest to hold and pour from jug at same time, but, got it done. Honestly, I think changing the oil on the 6.0 was easier and cleaner.
So my question to those that have do their own oil changes, what do you do to lessen the mess? Different drain plug/valve? Is the oil filter getting covered after loosening it just part of doing the process? I don't mind getting dirty, but don't recall getting or making this much of a mess in quite sometime.
