Cummins12V98 wrote:
ACZL wrote:
Did my 1st oil change yesterday and when I pulled out the drain plug (not on bottom of pan, rather rear side corner), oil came shooting out like a rocket at me. Most of it I got in drain pan, but some landed on blacktop, creeper and me. Thank goodness is had cooled a lot. Let oil drain from pan till hardly anything and then loosened filter. Like w/ the drain plug, good thing I had the drain pan under it as well. Couldn't believe how much came from it as it ran down the filter. Let that drain till and while it almost stopped, put pan plug back in. Found a couple pieces of wood that straddled the pan and placed a wire screen I found in garage to place filter on (top down) so oil would drain out. Installed new filter.
Once complete underneath, time to add new oil. Need a step stool and of course, funnel doesn't fit 100% and not the easiest to hold and pour from jug at same time, but, got it done. Honestly, I think changing the oil on the 6.0 was easier and cleaner.
So my question to those that have do their own oil changes, what do you do to lessen the mess? Different drain plug/valve? Is the oil filter getting covered after loosening it just part of doing the process? I don't mind getting dirty, but don't recall getting or making this much of a mess in quite sometime.
So Fish what say you??????
cummins,
I say try doing this on your RAM cummins filter! Removing an oil filter on a RAM '13-'15 is a royal pain in the arse to remove and having to wipe the oil off the suspension.
Try prefilling that filter and install it on your cummins too! :W
BTW... Perhaps you can help a cummins brother out on how to remove that oil filter! :W
cummins oil filter removalPunch the Filter VideoOP,
Try punching the filter to drain the oil. You can either do this or just unscrew the filter until oil starts draining around it until it stops. I change my oil on my 6.7 PSD using two oil pans (1 for the engine sump and 2nd for the oil filter) and not get a drop of oil on the ground. I don't have one but horizontal drain plug makes for a great application of the fumoto drain plug that many use with no issues.
