Cummins12V98 wrote:
fj12ryder wrote:
Cummins12V98 wrote:
I would not use the Fumoto because it can't be locked, too easy to have some jerk let your oil out.
I let my oil drain overnight. Then when I remove the filter the oil has siphoned down about 1/2" from the top and does not spill.
Seriously? You actually worry about that? Man, you need to move to different place. I simply can't imagine someone crawling under my truck and letting the oil out simply because I have the valve on there. Consider my mind boggled.
I don't "worry" about it!
I have no reason to spend the money on something that I can just use a wrench to remove and drain.
Sorry it bothers you so much that I have a different outlook on things than you do.
If not wanting to use a Fumoto bothers you this should put you over the edge!
LOCKS EVERYWHERE!!!
My mistake, I misused the word "worry". I didn't mean it as in something to fret about, but rather something that you would consider could actually happen. In all my imaginings the thought that someone would crawl under my truck and open the valve to drain my oil has never been there.
