Cummins12V98 wrote:
fj12ryder wrote:
Cummins12V98 wrote:
I would not use the Fumoto because it can't be locked, too easy to have some jerk let your oil out.
I let my oil drain overnight. Then when I remove the filter the oil has siphoned down about 1/2" from the top and does not spill.
Seriously? You actually worry about that? Man, you need to move to different place. I simply can't imagine someone crawling under my truck and letting the oil out simply because I have the valve on there. Consider my mind boggled.
I don't "worry" about it!
I have no reason to spend the money on something that I can just use a wrench to remove and drain.
Sorry it bothers you so much that I have a different outlook on things than you do.
If not wanting to use a Fumoto bothers you this should put you over the edge!
LOCKS EVERYWHERE!!!
Looks like you live in a bad part of town!
