oakbowery
May 14, 2015Explorer
euphoria18_79 wrote:
Sorry just at work at the moment.
The battery is still connected. For a brief moment, when i went to the bathroom which has the battery/water guages, it lit for a matter of a second.
There is no AC in the unit.
Plugged in, the only thing that works is the microwave. Fridge does not (havent tried using gas on it), no lights, no stereo, no fan. I turned on the red switch by the sink, i assume thats for the hot water tank?? and it did nothing as well.
When you say "the fridge doesn't work".....are you referring to the light in the fridge or the cooling part of the fridge? Have you left it plugged in long enough to determine that it's not actually cooling? The light in my fridge works off the 12v system so again if the battery is dead and converter is not working/blown fuse then the light wouldn't work in the fridge. The stereo also didn't work in my camper when I got it and it had an inline glass fuse on the hot wire running to the radio which was also blown. I first thought that I had a similar problem as you, but it turned out that I just had a random assortment of fuses blown that led me to believe it was a major problem. I think I swapped three fuses and everything worked as it should. From my personnel experience....I'd say check all fuses first and if that doesn't solve the problem then more detailed analysis may be necessary.
44,057 PostsLatest Activity: Mar 12, 2026
