time2roll
May 16, 2015Nomad
The 12 Volt Side of Life
Otherwise if it is just a 120v issue... turn all breakers off firmly and firmly back on. Do the outlets work?
Lots of stuff runs on 12v which can be powered by the converter or the battery. Check the 12v fuses especially the pair of main fuses.
Are you sure you have the battery in correct? Black is often B+ and white is B-.
44,057 PostsLatest Activity: Mar 12, 2026
