jmtandem
Aug 31, 2014Explorer II
Questions:
1. Any suggestions on the above process?
2. I could not get the rear closer than 1" side to side level. When I raised the low side enough the other side lost contact with the ground. What's the fix for this?
3. Is there any negative impact on the truck if you leave a heavy TC in the bed for weeks at the time when not in use?
4. Currently I'm not planning on any off truck support for the camper. Is that something I should reconsider?
Looks like you did a nice job. My only two comments are that I would support the camper under the floor with something. I used wood beams and cement blocks and lowered the jacks to the point where the floor was just touching the beams so the jacks also still provided some support. My second comment is that I never loaded or unloaded in the wind. Just a concern that things could get out of hand with the camper way high and the truck not under it even if only for a moment.
