3_tons
Dec 23, 2014Explorer III
mkirsch wrote:
Check the ratings of the receiver. It's generally on a sticker on the receiver itself, and if not, it's in the owner's manual.
2-1/2" factory receivers are rated higher than the standard 2", but they are still a far cry from a Reese Titan or a Superhitch.
Does your factory 2-1/2" receiver have a 2000lb WC tongue weight capacity?
Bingo, my 07 Dodge has a factory 2" rated at 1000 lbs. This hitch is welded in and doubles as a permanent frame member...Got (from etrailer) a Curt Commercial direct bolt on 2.5" rated at 2700 lbs which sits immediately below the Dodge hitch... With Reese extension problem solved... As others have said, determine your needs and tongue weight.. I added chains and turn buckles for good measure.
