Bedlam
Jan 15, 2015Moderator
If you go with a SuperHitch, it does not matter if you use 17K, 20K or 30K model when using the SuperTruss extension - The limitations when towing with the SuperTruss is the same across all the receivers and only changes based on the length of the SuperTruss.
The Magnum line of SuperHitches in 20K and 30K lb capacities have double ended stingers and hitch balls available to utilize these high receiver ratings. There are other companies making these heavy rated components, but you have to look at more specialty suppliers instead of a big box store.
