rburke's avatar
rburke
2 outlets in GFCI path not working
I have 2 outlets controlled by the GFCI that are not working and 2 that are. In the kitchen. there are 2 protected outlets, one works and the other doesn't and the outside receptacle does not work.
The GFCI receptacle is in the bathroom, seems to test and reset properly - but when reset still have those 2 outlets out.
Was thinking about replacing the GFCI but I am not sure, or maybe the non-functioning outlets.
Any ideas? I may need to call an electrician in on this one but thought I would try here first. Thank you!
2012 Country Ridge 40FKSS
  • Sounds like there is a broken connection to the outlets that aren't working. Most likely at at the last outlet in the chain that is working or the first one that is not working.
