- stevemorrisExplorer
deltabravo wrote:
jerem0621 wrote:
You can pick one up at Harbor Freight for a few bucks.
Pretty sure they cost more than a "few" bucks.
ive seen some of the junk from horror freight, we have a Canadian equivalent, princess auto. lots of cheap and nasty junk with a few good things mixed in. - LynnmorExplorer II
BarneyS wrote:
Harbor Freight sway bar $30.
Guess it depends on what your definition of "few" is. :p:B
Barney
And don't forget you can get 20% off with a coupon anytime. $24 is fewer yet! - BarneySNomad
Pretty sure they cost more than a "few" bucks.- LVJJJExplorer
Gulfcoast wrote:
I tried two sway bars years ago but wound up with an equal-i-zer hitch from Amazon. No more sway or wiggle on my rig.
same here. Even with two sway bars, trucks would push me over and there would be a slight wiggle after they were past. With the Equal-I-zer there might be a push but its less noticable, but no wiggle at all. - HuntindogExplorerThe difference in performance between the integrated sway control hitches such as the DC, EQUALIZER etc. and the add on friction bars comes down to setup.
The add on control hitches are not nearly so setup dependant for sway control. One can have the WD setup pretty far off, and the add on sway controls will still help it quite a bit...
BUT, if one gets the WD part dialed in, the entire system works better.
The integrated hitches rely on setup to a great degree to perform properly. In other words. they force one to set them up right, or the sway control will work poorly if at all.
This is the reason there are so many add on sway controls in use, and why I think that newbies should start out with them. Most people don't have the knowledge and/or patience required to do it right when they are just starting out... Some may never get to that point. Many are just occasional users that want to go camping a couple of times a year. The add on controls are just the ticket for them.
This is not to say that the add on controls are inferior,,,, just more user friendly.
The integrated SC hitches are more difficult to setup, but once set up, they are more convenient to use.... IOW better suited to the frequent, more experienced user.
But back to the OP, yep, you have found out what many of us have. a add on friction control or TWO, can be a VERY effective sway control system.
Happy camping. - GulfcoastExplorerI tried two sway bars years ago but wound up with an equal-i-zer hitch from Amazon. No more sway or wiggle on my rig.
- tewitt1949Explorer IIOk here's what I found from installing 2 sway bars. I should have done it 23 years ago. It was rock solid when vehicles and 18 wheelers pass me. I can now let go of the steering wheel when big trucks pass and the wheel don't move a bit. Now its a pleasure to drive, I don't even know the trailer is back there.
- LarryJMExplorer II
ScottG wrote:
LarryJM wrote:
Based on my non techincal assessment of the Equal-i-zer vs Reese dual cam I can see one actual real difference and that is the Equal-i-zer produces an even "friction force" for all 'YAW ANGLES" where as the Reese Dual Cam "friction force" is larger the greater the "YAW ANGLE". Not sure if there is much advantage of one over the other except it seems that the Dual Cam would allow a trailer to "wiggle" slightly back and forth off the center line position since the friction force would be less for these very small "YAW ANGLES" than the Equal-i-zer which would have a larger "fricton force" for very small "YAW ANGLES". Also, it seems from all the posts by users of the Dual Cam is that it needs to be adjusted much more accurately to ensure the bar notches are on the cams correctly than the Equal-i-zer which doesn't have that concern.
Larry
There's no evidence that the initial restriction of either is stronger than the other. In my own experience, the DC has worked much better than Equalizer and I don't believe it allows "wiggle". It also doesn't make the strange noises that he friction part started making after getting wet a few times.
The DC does indeed need to be adjusted correctly. This part took my perhaps another 30 minutes and then a couple of checks on the road. Worth it IMHO.
YMMV.
Scott
The only evidence I can point to on the differences in the "friction forces" differences between the Equal-i-zer and Reese Dual Cam as a function of "YAW ANGLE" is the comments saying there is from Ron and while I can't point to a specific post of his on this IIRC he did some fairly extensive mechanical calculations of the relative forces as a function of "YAW ANGLE" for the Reese Dual Cam in one of his analytical post on that system in the past.
Yes the "wiggle" comment was purely speculation on my part based on the variable friction force effect for the Dual Cam.
Larry - HuntindogExplorer
ScottG wrote:
Any slight movement from straight immediatley creates more tension in the oposite cam which resist the sideways movement.
It appears that you haven't thought your theory thru.
Movement from straight moves the bars of BOTH cams. One CANNOT move without the other moving.
And then you gotta understand the concept of leverage as to what happens next. The bar on the outside of the turn(in a matter of speaking) gets longer,and the one on the inside gets shorter. The one on the outside will be able to exert more force, while the one on the inside will exert less.
You can experience this yourself with a wrench. Shorten up your grasp on it and see how it gets harder to tighten a bolt.... Then grab the wrench by the end and see how much easier it gets.
IMO, the net effect is a wash.
This also doesn't really jibe with your thoughts as to having one bar looser than the otherScottG wrote:
The cam will not move, only the bar slides.
And that is why it is a FRICTION sway control.
44,068 PostsLatest Activity: Jun 01, 2026
