- ScottGNomad
LarryJM wrote:
ScottG wrote:
You would be better off making some adjustments to try and reduce the effect. More spring rate or more weight at front of trailer.
Also, a better hitch like the Reese Dual Cam with active sway control will both resist sway and push the combination back in line.
There are other brands that offer active sway control but I've not used them.
It appears you really do not understand these sway systems since the Reese DOES NOT RESIST SWAY and DOES NOT PUSH the combination back in line nor is it what could be called "ACTIVE SWAY CONTROL". The friction type sway bar sytems and the Reese and Equal-i-zer all are "FRICTION TYPE" sway systems .... they just perform the same function in slightly different ways.
Larry
No Larry, it's you that doesn't understand and I've seen you argue this way in the past.
In Reese's own literature it explains that friction plays no part in its function. And it IS active. The more sideways the trailer gets, the stronger the spring bar pushes back because the cam is climbing the bar and making it stiffer. Friction doesn't limit movement like on the system your familiar with. In fact, you can lubricate every part of it without having any impact on its function.
But this has already been explained in detail to you but you either refuse to learn or simply cannot understand it. If you had the system you would probably understand it better.
But for now, you and I and Reese will just have to have different opinions. - LarryJMExplorer II
Larry - ScottGNomad
DutchmenSport wrote:
If your hitch head does not have a wing on the top on both sides where the little ball fits, you are going to have to get a new hitch head so you can get a friction bar on both sides. You'll also have to add the second ball mounted to the trailer frame on the opposite side. Then, you'll have to find a left sided sway bar, as everything will be turned opposite from the right side set up. By the time you purchase a new hitch head, install all the parts for the second sway bar, and re-install your hitch ball, you'll be much better off to just toss the entire system and purchase a new weight distribution system that is much simpler and does it all. Systems like the 4 point Equal-i-zer and the Reese Dual Cam systems come to mind immediately.
Now, if your hitch head already has the second wing with the hole for the ball, then adding a second friction bar should be pretty simple, but you'll still need to mount the left side ball on the trailer A-frame.
More info, click here.
X2. If you udecide to start form scratch (my suggestion) then the Dual Cam is a drastic improvement over frictin hitches.
(Some simply don't understand how this system works - ignore them) - Mickeyfan0805Explorer
tewitt1949 wrote:
I think the tongue weight is 800 lbs.
The 'I think' in this sentence suggests, to me, that you are basing your tongue weight on the 'dry' data of the trailer - which is a useless number. IF this is where you are getting the number, then your tongue is NOT 800 pounds, it is higher than that. It may be too low, it may not be - you won't know without going to the scale to weight it. As others have said, your tongue weight should be in the 12-15% range of your total trailer weight. But, I would not start trying to redistribute the load to the tongue without knowing what the real weight is.
Also, just confirming that you are actually talking about sway. I, too, get pushed by large rigs (there's really little way to avoid that with a large trailer in tow and big rigs flying by), but I get pushed as a single unit - trailer and truck together in line. That is different than sway, where the 'tail wags the dog,' which I don't experience at all. If it is, in fact, sway, check your weights to make sure you are in ratings and then, if you are, begin working with more/better sway control as a solution.
All I am suggesting is that you make sure you aren't masking a problem with your set-up with more sway control. Make sure everything is in line on weights and capacities and THEN use better sway control to tune it in. - DutchmenSportExplorerIf your hitch head does not have a wing on the top on both sides where the little ball fits, you are going to have to get a new hitch head so you can get a friction bar on both sides. You'll also have to add the second ball mounted to the trailer frame on the opposite side. Then, you'll have to find a left sided sway bar, as everything will be turned opposite from the right side set up. By the time you purchase a new hitch head, install all the parts for the second sway bar, and re-install your hitch ball, you'll be much better off to just toss the entire system and purchase a new weight distribution system that is much simpler and does it all. Systems like the 4 point Equal-i-zer and the Reese Dual Cam systems come to mind immediately.
More info, click here. - KD4UPLExplorer IIWhat you need is a lot more tongue weight. If your 8,500 pounds empty you're probably close to 9,500 loaded. You should have at least 10% if not 15% tongue weight. You've only got 8% if your tongue weight is truly 800 pounds. I'm not surprised it is swaying a lot. Can you move some weight forward? Where is your water tank; in front or behind your axles? If it's in front towing with it full would help. Try putting all your heaviest gear in the forward compartments.
Are you using a WDH? It may be set too tight and not letting enough of the tongue weight press down on the truck's hitch. With a modern truck like that I would bet you might even be better off without a WDH if that's all the TW you've got. - LynnmorExplorer II
My trailer weighs 8500 empty.
Since we now know that you have inadequate tongue weight, that is the problem that needs fixed. A sway control is not a fix. - mgirardoExplorer
tewitt1949 wrote:
I should have mentioned I have a 2018 Chevy 2500hd duromax. The sway problem didn't just start with this truck.tewitt1949 wrote:
I think the tongue weight is 800 lbs.tewitt1949 wrote:
My trailer weighs 8500 empty. I know tongue weight is important.
Yes tongue weight is important and if your numbers above are accurate, then your tongue weight is too light. Your 8500 lb empty TT probably weighs closer to 9500 lbs when ready to take camping. Ideally, your tongue weight should be between 12% - 15% of TT, so 1,140 - 1, 425 lbs for tongue weight.
-Michael - tewitt1949Explorer III should have mentioned I have a 2018 Chevy 2500hd duromax. The sway problem didn't just start with this truck. I've been pulling the trailer since 96 when new. I think the tongue weight is 800 lbs. I always have put max pressure (80 lb) in all 8 tires on the truck and trailer and that does help a lot. The last time I pulled (a couple weeks ago) I did tighten the pressure on the sway bar (tighter) and that did help and took a lot of sway out of it. It don't go back and forth while just driving, but wiggles a little when big rigs pass and some other vehicles. My trailer weighs 8500 empty. I know tongue weight is important. The reason I'm thinking 2 bars would be better is after tightening the one sway bar did help quite a bit and now seems to be more stable, I assume 2 bars would would be even better. It would put even pressure on each side of the tongue and not excessive pressure on just one side. Maybe the whole problem is I just didn't have enough swaybar pressure all along. When it sways or wiggles it makes for a white knuckle drive.
- HuntindogExplorerIf you read the instructions that come with the friction sway bars.... They all state a limitation on length and or weight for a single sway control. Usually 24-26' 5-6K.
You are beyond that. You need two for that TT. And coming from one who has used a single and double sway control, it DOES make a difference.
And do not believe the malarkey about the integrated sway control hitchs having"active" sway control. The DC, EQUALIZER etc. all use friction based sway control.
There are ONLY three hitches out there that use active sway control. The Pullrite, the Hensley, and it's copycat the Propride.
They have some drawbacks, or everyone would be using them. But that is another discussion.
44,067 PostsLatest Activity: Jun 05, 2026
