needgas__ExplorerMay 18, 2014!2 volt Electrical issue. Please helpHello all, Not sure if I have a big problem or I am overlooking something. Here is the problem. When running on 12VDC power (Battery or TV power) my 12VDC system does not run. Water pump, slide motor...Show More
shootedExplorerMay 18, 2014The "junction" is most likely a circuit breaker & is consistent with your problem.
Related ContentElectrical outlet issuesElectricElectrical IssuesElectrical assistanceElectrical/Battery issue.
