RedRocket204
Jul 02, 2013Explorer
bfast54 wrote:
... I haul trailers all over the country.........for a "bumper pull".....I E travel trailer.....I have to put in the huge hitch, that I remove so I dont bust a shin,when not towing...then try to match up hitch,and ball, which you cant see,so,many tries to get in right spot,even with spotter....get right height, crank down...power or manual,then wrestle with weight bars, but some also use equalizing/sway bars.....set them for proper hieght,weight,level
Your post gets a bit dramatic for hitching a TT. Sure, if you are hitching that one TT for a single pull, then switching to a different TT for a different pull, yes, adjustments are made. But those same adjustments are not made every time on the same TT.
:S
44,056 PostsLatest Activity: Jan 22, 2026
