Billstar1 wrote:
Just brought a new Chev Silvarado 1500 with 20" Goodyear Eagle tires. When doing a little research on the tires, which I wish I had done before buying the truck, found out they're passenger car tires. I'm a little dubious about towing with them. I'm not having much luck finding a rated 20" tire, either "D" or "E". Anyone know of such tires? BTW, the truck has the 5.3, 3.42 re-end and HD tow package. Tows my Jayco Whire Hawk 30 DSRE pretty darn good.
THANKS
I am not sure that there is a real (technical) issue is other than your doubt. As long as the tires and axles are not overloaded by the as-weighed (on a scale) weight of the tongue, and it tows pretty darned good, then the 20" tires are up to the task. :)
I have a silimar TV as you do and it tows well with a 600# tongue load. When not towing, which is most of the time, I appreciate having the tires I have (same as yours) as it gives decent performance. It might not be the best tire in the world for our trucks, but the engineering says its okay for the rated specs for the truck so that means it is good enough.
That said, when the time comes for me to replace my tires I will likely not get the Eagles as there are better tires out there, and while I am at it I will look at what is available in the XL load range in a P type tire. For you that might provide the extra margin needed to remove your doubts. There are lots of these tires listed at places like Discount Tire.
