Camper_Jeff___K
Dec 18, 2018Navigator
SidecarFlip wrote:Camper_Jeff_&_Kelli wrote:
My left rear leaf spring is bent near the front shackle causing the left side to be 1-1/2" lower than the right side. A bad left lean when the TC is on the truck. Has anybody replaced or able to recommend a heavier duty spring, F350, F450, aftermarket, that is a direct replacement for the springs I have. I don't care about ride smoothness. I want better TC load handling capacity.
I replaced the spring packs in my 97 F350 4x4 myself and added an extra leaf. It rides like a tank empty but with the camper, rides like a caddy. Got the packs and springs at NAPA, got the bushings and the through bolts too. Did the front too.
Good to know. I expect a tougher ride but if I'm going to use the truck for the camper, the rough ride will be worth it. I may do front springs at a later date. The 5.4 liter engine is lighter than the diesel.
I get the springs tomorrow and the balance of parts Friday. Excited!
44,068 PostsLatest Activity: Jun 14, 2026
