zzyzxpat's avatar
zzyzxpat
2000 Ram change from 16" wheel to 18"?
I am looking to see if anyone has changed up their 16" wheels to either 17" or 18", whichever can handle more weight. Having read posts on going to 19.5", I don't think I want to go there. Something that would handle 3800-3900 lbs should work I think. If you have done this, could you suggest a wheel vendor and what tires did you go with. Thank you for your time. Pat
  • Ask that question on Cumminsforum.com.
    There’s even a specific “tires and wheels” section.
    You’ll get good info specific to your 2000 Dodge there.
  • Look on Craigslist for a set of wheels and tires from a new Ram.
    Numerous brand new sets for $1000 or less. 285/70/18
  • romore wrote:
    I don't think you will be happy. It will be like changing your diff gear to a higher ratio (lower numerically) which will kill towing ability.
    Tires that are the same height with larger wheels will not affect effective gear ratio.
    Op,
    18s will carry more weight.
  • I don't think you will be happy. It will be like changing your diff gear to a higher ratio (lower numerically) which will kill towing ability.
