Campfire_Time
Oct 21, 2016Explorer
Hudson54 wrote:Campfire Time wrote:
We had to order the spare tire as an option. It was mounted on a little cage under the tongue. Our X20E has the same setup. Maybe that's an option if you can find the parts?
That might work now that I've lifted it 4 inches and put 15inch wheels/tires on it. This thing was so low with the original configuration and 13 inch wheels that at a certain RV park we stayed at, the dump valves were BELOW the receptacle. I'm sure having the spare mounted that way wouldn't have worked either.
Mine was that low too. Though I never had any problems with mine, save for dragging the skid bars a few times when I first got it. I think the reason it worked is because it was in the front. You typically don't drag the front. In later years Jayco offered a 2" lift kit as an option.
