- BurbManExplorer IIIThe computer is pretty sophisticated and as far as I know everything else should set a code that can be read with a scan tool. The way it was explained to me was that since the 8.1 has no distributor, the PCM relies on the crank sensor to know where the crankshaft is so it knows when to fire each spark plug. When the sensor doesn't read or sends an unusable signal, the PCM won't fire the plugs if it doesn't know where the crank is to avoid severe engine damage. So the instant that the PCM detects a crank sensor error it also shuts down to disable the ignition, and in the process interrupts the process of storing a code.
By the way, let us know if that solved the issues you were having with the truck randomly shutting down. - lone_rangerExplorerBurbMan, I had the crankshaft sensor replaced yesterday for $336. To your knowledge are there other issues that can cause engine failure without the "service engine soon" light turning on and entering a code in the system?
- BurbManExplorer IIIYes there was but I believe the campaign ended in 2008. Another reason to have the dealer do the job, there are tricks to getting out a broken sensor but it's not an easy job...
- buckyExplorer IIThere was a recall on those IIRC. Run your VIN. A real problem if it breaks coming out.
Nomadac wrote:
What is the problem when the crankshaft positioning sensor fails? I have a 2001 Model with 52,000 miles with no problems.
See this thread - wnjjExplorer II
SidecarFlip wrote:
That is in a terrible spot. Mine is on the front of the motor, just below the harmonic damper. 5 minute job. Changed it twice myself.
Seems like they planned well for failure on that one, apparently with good reason. ;) - austingtaExplorer
I think it's just a random failure. You will stop moving and not move again until it is replaced. I had it happen on a just few weeks old truck once. - NomadacExplorerWhat is the problem when the crankshaft positioning sensor fails? I have a 2001 Model with 52,000 miles with no problems.
- SidecarFlipExplorer IIIThat is in a terrible spot. Mine is on the front of the motor, just below the harmonic damper. 5 minute job. Changed it twice myself.
- lone_rangerExplorerthat makes sense. I'm going to try to get it R&R today or this week and I'll post the results
