andalusiagirl's avatar
Oct 08, 2013
2002 Coachman Cascade roof maintenance help!
We are looking to treat the roof our our 'new to us' 2002 Coachman travel trailer. But we cannot find any info on the material the roof is made of and what type of cleaner and sealants to use. Can anyone help? Much appreciated!
  • wrvond wrote:
    More specific information would help get a more accurate answer. However, it is most likely an EPDM rubber roof. Regardless of the type of roof, cleaning with a mild soap, such as dishwashing liquid is good. Small cuts/tears can best be repaired with Eternabond tape. Sealing seams can be done using Eternabond tape as well, or Dicor self leveling sealant.
    Thanks!
  • More specific information would help get a more accurate answer. However, it is most likely an EPDM rubber roof. Regardless of the type of roof, cleaning with a mild soap, such as dishwashing liquid is good. Small cuts/tears can best be repaired with Eternabond tape. Sealing seams can be done using Eternabond tape as well, or Dicor self leveling sealant.
