98silvz71
Mar 31, 2017Explorer
snowpeke wrote:
My 02 Duramax at 80,000 miles started leaking fuel under the motor, anybody have that prolobem. Looks like it's going in the shop.
Where exactly is it leaking from? I know that if you haven't done it already, the fuel filter head seals wear out and it will start leaking from there. The fuel filter is located on the passenger side, just under the intake tube. If you have fuel in that area, it is most likely that leaking. I have already done this repair on 3 Duramax's. 2 LLY's (04.5 - 05) and 1 LBZ (06 - 07) trucks. Only 2 of them had problems with losing prime, where you would have to pump it up to the filter head again to get the truck started.
44,026 PostsLatest Activity: Feb 22, 2025
