DD716TED
Apr 09, 2015Explorer
dodge guy wrote:
That upper bolt on the pass side will not come out unless your remove the bolt in reinforcement. There are 2 bolts under the frame rail right below the big bolt. Remove those 2 and the big bolt and it pivots out along with the reinforcement. I have mine out right now, waiting on the links and bush to show up on wed. Very easy to do.
Just received new links.. As luck would have it they have grease fittings which will not work on the F-250 (5.4l engine).. to close to exhaust manifold.. now have to find links w/o grease fittings..
44,056 PostsLatest Activity: Nov 19, 2013
