Bert_the_Welder
Sep 30, 2020Explorer II
BurbMan wrote:
Yes, Eternabond tape is very hard to apply straight and wrinkle-free. It looks like kind of like the kid that has adhesive tape on the bridge of his glasses...however, the micro-sealant on the tape does seal up inside those folds, so no water can get in. It's important to note that EternaClean solvent should be used to clean and de-grease prior to applying the tape. If the tape is installed correctly and with good adhesion, no water will get behind it anywhere, ever.
I did the seams on my TT when it was new and never had to worry about any leaks or annual re-sealing.
Congrats!
Am thinking of using the 2" EBond tape on my roof corners that need redoing. The wrinkling is my concern as well. Though I agree, if the wrinkles are pinched together it aught to be just fine. I'm going to try and make little cuts as I go down the nose curves, allowing for overlapping instead of the wrinkles. I'll see how that goes. Going with the 2", if I can get it, in hopes it will be covered by the trim when reinstalled.
So....... ya gonna run the sprinkler on it to test for water tightness? XD
