BurbMan
Oct 05, 2020Explorer III
Good eye...actually the umbilical is pinched between the floor and the 2x10. That part of the floor is sheet metal that that goes under the holding tanks. What you are seeing under the access door to the dump valves is a removable piece that enables you to connect the dump hose. Having the cord pinched in there pushed that sheet metal out of alignment somewhat. I can tell you the floor is solid because I replaced that section under the door!
44,070 PostsLatest Activity: Jul 11, 2026
