- drsteveExplorerIs charging the battery the only thing it is failing to do? Do you have 120v power when plugged in to shore power? How about 12v lights in the camper?
Do you have a multimeter? - d0riann1ExplorerAll fuses and breakers are good ...when we use a battery charger to charge it full power in camper however shore plug not making converter charge camper
- Old-BiscuitExplorer IIIConverter
120V AC IN...13.2V DC OUT
Battery Disconnect ON so battery is connected to DC System
Battery POS Cable in-line Fuse (DC Circuit Breaker if used) TESTS good
Battery Cables connected properly---hooked up backwards Reverse Polarity Fuses on Converter BLOW - donn0128Explorer IIFuse? I seem to feel your throwing parts at the problem without actually proving whats wrong. Start with the basics. Using a volt meter trace power starting with the 120VAC to the converter, then switch and verify 12VDC out of the converter.
44,065 PostsLatest Activity: Apr 14, 2026
