subcamper's avatar
subcamper
Explorer II
Apr 08, 2015
2002 Suburban K2500
I have a 2002 Suburban K2500 with the 8.1L engine. The muffler has developed a few holes in it. I temporarily patched it with a piece of sheet metal, pop rivets, and hi-temp RTV. The pipes seem in good shape.
Our local muffler shop chain says they don't list an aftermarket exhaust system for it, or even a muffler. He says the muffler should be similar to a 2500 pickup, so bring it in and they'll see what they can do.
Anyone replace a muffler and/or exhaust system on a sub like this?
I did find a post by BurbMan back in 2012 where he installed a Flo-pro muffler that sounded like the stock one (I don't want a louder muffler). If you are reading this BurbMan, how has the muffler worked out? We have bad winters here and I was hoping for a stainless muffler. I think the Flo-pro was not stainless.
Steve
  • BurbMan wrote:
    Hi Steve, muffler has been problem-free so far. I did a ton of research on this, and you can't buy just the muffler from GM parts...it comes as part of an "assembly" that includes the front pipe, one of the catalytic converters, etc and the dealer price is $2000! Everything aftermarket was a "performance" exhaust and my biggest fear was getting a drone in the cabin while towing.
    Finally decided on the FloPro 2506. Was $150 shipped, and it cost me another $150 to have the local exhaust shop weld it on. I even talked to the local shop for advice before ordering the FloPro, and he said that mufflers perform differently depending on the vehicle. A muffler on vehicle A may be fine but may drone if installed on Vehicle B. So while he had done installs on other 8.1 trucks, he had never done an 8.1 Suburban, and couldn't guarantee how the same muffler would perform.
    If you scroll down to the bottom of the Flo Pro page in the link, they have a sound level chart. The mufflers that fit the 8.1 come in a few different sound levels, the 2500 is the one they are saying is the "stock" sound level, the 2506 is a little louder, the 2505 is the loudest.
    I was also concerned that it's not stainless, and would have preferred a stainless unit, but more important to me that it be quiet when towing. So far it's held up well, and I'll likely get another of the same when it's time.
    I was also looking for something that was a direct fit since I planned on installing it myself, but once the new arrived and I saw the SIZE and weight of the muffler, I decided that changing was a job for a guy with a LIFT!
    Thanks for the update, BurbMan!
    Yes, I looked at buying the stock factory muffler (which includes a bunch of pipes attached , but noticed the $2000 list price that you mentioned. Even at gmpartsdirect it would have been $1250 (plus a lot of shipping).
    What is the advantage of the 2506 over the "stock-sound" 2500? Does the 2506 flow better or just have more sound?
    I also need to check the pipes to makes sure they are OK. Just in case, have you found a place that has pipes for the sub, or does the muffler place have to custom-bend new ones from blanks?
    Thanks
    Steve
  • Hi Steve, muffler has been problem-free so far. I did a ton of research on this, and you can't buy just the muffler from GM parts...it comes as part of an "assembly" that includes the front pipe, one of the catalytic converters, etc and the dealer price is $2000! Everything aftermarket was a "performance" exhaust and my biggest fear was getting a drone in the cabin while towing.
