B_O__Plenty
Jul 05, 2012Explorer II
Slated4Greatness wrote:
AFE intake, Magnaflow Exhaust, and see what that does for you. If it isn't enough go with a tuner of choice. An engine is an air pump so the more you get in and out the better it will run.
And if that still doesn't get you up the hilss like you want to go then add a procharger! :D
Don't waste your money on an intake or exhaust. All that will change is it will be noisier. Your engine has electronic controls that only allow it to use as much air as it needs. Making more available won't change anything. The companies that sell this junk always start their claims with "adds as much as". If it was this easy to make more power the factory Engineers who designed these engines would use it.
B.O.
