jay427's avatar
jay427
2003 Jayco Hybrid Travel Trailer 18F
What are the thoughts on this rig?
clicky
From the add wrote:
2003 Jayco Kiwi Hybrid Travel Trailer, Model 18F. The trailer is in very good condition and we are the second owners. Lots of storage inside for a small camper. Queen Flip Out Bed on one end and a Double Flip Out Bed on the other end. Absolutely no rips in the canvas or screens, they are in perfect shape. Dinette also folds down for a total sleeping potential of 5-6 people. New tires within the last 500 miles. Very light at ~ 3700 pounds making it easy to tow. Does come with an equalizer hitch if needed. Amenities... Air Conditioning, Outside Shower, Crank Down Stabilizer Jacks, Digital TV, DVD Player, Awning
Anybody know the black tank size, I recall those tanks were like 6 gallons but not sure?
Have had a TT, PUP, etc. I was just nosing around and for the little we will go this would not be a big outlay in cash. I would think it would need to be below $5,000 however.
Thoughts?
  • Price is always negotiable. Check out camper real good, go up on roof and walk around looking for soft spots, old cracked caulking, tears in the membrane.
    Inside, let your nose do the checking, if you smell a damp musty odor, or any other odd odor, there probably is or at one time was a leak and there may or may not be a mold issue. Check corners of the campers, check inside cabinets in the corners and bottom areas for damp or soft spots. Check bunk end door seals and caulking around outside of bunk end. Be through and take your time checking things out. Good Luck.
  • Classification Ultra Light Weight
    Length 18'2"
    Width 7'6"
    Height 8'9"
    Interior Height 6'6"
    Hitch Weight 405 lbs
    Dry Weight 2,760 lbs
    Gross Weight 3,750 lbs
    Cargo Weight 990 lbs
    Fresh Water Capacity 30 gals
    Grey Water Capacity 23 gals
    Black Water Capacity 23 gals
    Furnace BTU 16,000
    Sleeps 6
    Tire Size ST175/80R13B
    Slides 2
    Exterior Color White with Blue Exterior Graphics
    Interior Color Blue Vista with Oak Cabinetry
  • http://www.rvingplanet.com/brands/jayco/kiwi/expandables/
    Check this out for Specs.
    I think 5K would be a reasonable price in good condition. NADA says $5045. Average cond.
    Be sure to check for water damage around front bunk.
    http://www.rvingplanet.com/models/jayco/kiwi/18-f/
