Massey16's avatar
Massey16
2004 F-150 Tow Mirrors
Hi all!
I recently purchased a 2004 F-150 Supercrew. The passenger mirror casing is broken, so I'm looking to get a replacement. I figured that I might as well upgrade since I need a new one anyway. They are factor power mirrors with heat and the turn indicator. Looking for recommendations on what to get.
Thanks!
  • I got a pair of a 2005 lariat, send me a pm
    Frank.
  • Massey16 wrote:
    Did they make tow mirrors for F-150's or only the larger trucks?
    they did for the 2010 and newer. And since it is the same body style. they should work on a 2004
  • Did they make tow mirrors for F-150's or only the larger trucks?
  • Car-part.com will search junk yards for you across the country. I did a quick check and found used OEM mirrors for $135-$325 each. I'd rather have brand new aftermarket clones for less!
  • Massey16 wrote:
    Those do look nice.
    What factory mirrors (models & years) would be a bolt on replacement? I wouldn't mind checking a wrecking yard for used mirrors.
    Until 2015. F150s have not really had a body change since 2004. Seems any thing since 2004 should bolt on.
  • Those do look nice.
  • You can buy mirrors off eBay, either the whole assembly or just the glass. I've done it, the main thing if you buy the glass is to go and get some better tape from an auto parts store, to stick the new glass on. The mirror glass is fine but the tape they send is worthless. You can buy heated glass.
  • Aside from those mentioned above, maybe check a wrecking yard.
