jodeb720
May 02, 2020Explorer
Bedlam,
Thanks for the reply. You hit the nail on the head.
The factory Trailer Relay box is located under the hood - and when I opened the box, there's four (4) relay's and one 10 amp fuse - which I tested and it's good; However there are also two (2) additional fuse locations.
I went through the manual, twice, and I can't find any documentation for it.
Mitch gave me the online version and I went through them as well, and I can't seem to find any docs.
I've found the wiring diagram - which I can go through (eventually) but it would be much easier if the manual had notes on the fuses. It could be something as simple as missing the two fuses - but at what amperage?
What about the relays? I could test them as well -
Thanks!
Josh
FactoryTrailerRelayLocation
Thanks!
Josh
44,068 PostsLatest Activity: Jun 14, 2026
