JIMNLIN
Sep 11, 2017Explorer III
GVWR is a poor number to use for how much load is placed in the bed of a truck as evident of some newer gen trucks with a high gvwr based payloads are exceeding the trucks rear axle numbers. The op has a older 1500 truck with a low 6400 gvwr so it can be safe to use it or the trucks small RAWR package (3800 ?).
LDT makers aren't about to produce a truck that isn't up to using the sum of the axle ratings used as its gvwr. Nor are they using one ton DRW rear suspension under a 1/2 ton truck.
Like Ford fleet service weight specs tell us;
4) Gross Axle Weight Rating is determined by the rated capacity of the minimum component of the axle system (axle, computer-selected springs, wheels, tires) of a specific vehicle. Front and rear GAWRs will, in all cases, sum to a number equal to or greater than the GVWR for the particular vehicle. (snip)
