Super_Turtleman's avatar
Jun 01, 2014
2005 Aerolite 30BHSL Slide-out Won't Retract
Hi everyone. New to the forum. I have a 2005 Aerolite 30BHSL. I'm camping and it's time to go home and I can't get the slide-out to retract. I'm looking for the relay control module and the motor so I can manually override it but im having no luck. My battery charger says the battery is charged and I don't know what the problem is...but I'd like to be able to override it and retract it so we can head home. Does anyone have an idea where the location is so I can do it? Any help is greatly appreciated. Thanks.
PS. When I push the slide out button in either direction, I don't hear anything happening.
  • Btw, thanks everyone else for taking the time to read this and think about it. I'm glad it ended up being so simple. Lol.
  • Thanks campingfan, that was it. There was a fuse on the module that just fell off. I put it back in and am good to go. Thanks a ton!
  • you may have to pull the carpeted face plate off that is in front of the couch. I seem to remember the couch sits on a platform, the motor is in that platform.
  • I had a 2004 model. I think...memory is getting bad...that it is under the couch. You should have a rod with a long handle and can reach the area that you have to attach the rod to.
  • As far as I can see the fuses are good. I charged the battery on my charger and its good. As for the type of slide, that I'm not sure of. It's an electric slide-out but other than that I'm not sure if there's something else you need.
