jimlj's avatar
jimlj
2005 Alpenlite Aspen information needed.
Hello.
I recently purchased a new to me Alpenlite Aspen 28' bumper pull travel trailer. If anyone can direct me to a owners manual I would be very appreciative. It appears the manufacturer is no longer in business so contacting them is not an option. I have found most instructions on line for the appliances so that is not a problem, but things like the slide out operation and maintenance and winterizing instruction would be helpful. Right now the slide out works flawlessly, but I worry about it failing to retract some day when I get ready to head home. I assume there is a way to do it manually?
Winterizing has me concerned as freezing temps can happen any time now where I live.
Any help or advice would be appreciated.
1 Reply
  • Owners manuals are not worth the psper their printed on. Most are too genearic to be of any use. Search online for winterizing i structions. Alpenlite used to have a very active owners group. You might nose around the net to see if there still active.
