burningman
Feb 11, 2017Explorer II
Because if you do make the effort to install a Stable Lift properly, it's a whole world better and easier than corner jacks. Not only is it way, WAY stronger and more stable than corner jacks, it makes loading and unloading easier than anything else ever. You back under the camper, press the button to retract the lift, and it clamps itself onto the truck. No separate tiedowns.
To oofload, you press the button to lift and drive out.
They are always a labor intensive custom install. You have to pull out appliances and install reinforcements and if you have slide outs I feel you need to do even more beefing up. But after that, you're on easy street and a lot safer.
If you ever used one, you'd understand.
44,070 PostsLatest Activity: Aug 07, 2026
