FishOnOne
Mar 01, 2016Nomad
blofgren wrote:mabynack wrote:
Background: The 6.0 was built by Navistar for Ford. Ford sued Navistar because the 6.0 had the most expensive recalls of any engine Ford has ever put into its vehicles. Recall costs per unit are around 10,000. Navistar responded to Ford's suit by saying that they had designed the engine to be a 300 HP engine and Ford had retuned it to 340 HP to beat its competitors. The internal components of the engine weren't designed for the additional pressures and they failed.
This was the first generation of diesels to use Catalytic converters and pollution controls, so a lot of the issues were growing pains. One of the components that frequently fails is the Exhaust Gas Recirculation Cooler. The EGR injects small amounts of burned exhaust back into the combustions chamber to reduce pollution and allow the engine to run cooler under heavy loads. The cooler uses engine coolant to cool the 1400 degree exhaust before it's injected back into the engine. The cooler sometimes gets plugged with casting sand leftover from manufacturing the engines and blocks coolant from entering the cooler. At that point the EGR cooler can melt, allowing engine coolant to enter the combustion chambers. Small amounts of coolant in the combustion chamber will appear as white smoke under load and you can see bubbles in the coolant tank. If the hole gets too large and allows too much coolant into the combustion chamber you get a hydro lock condition that can bend connecting rods and blow the tops off pistons.
Another problem with the EGR Cooler is caused by using an improper coolant. The high heat from the EGR cooler can cause coolant to form silicate solids which will also clog the cooler. Ford/Caterpillar make a special coolant that will not form silicate when exposed to the high heat.
Coolant travels through the engine oil cooler on its way to the EGR cooler, so if the EGR cooler gets plugged, the engine oil cooler stops working.
The engine also uses high pressure oil to actuate the injectors. The pressures can run over 3500 psi. It's very important to keep clean oil in the engine. The High Pressure Oil System has O-rings that will eventually leak. They're located under the valve covers, so the leak is internal to the engine and you won't notice any oil on the outside of the engine. The engine gradually looses power.
Another problem is the Fuel Injector Control Module (FICM). I've had to replace two of them on my truck. One of Ford's software updates increased the voltage that the FICM operates at in order to increase the temperature and speed the warm up. The FICM wasn't designed for the additional voltage and it would melt the solder connections. I believe that Ford changed the voltage back to the intended level on a subsequent software update. There are companies that sell remanufactured FICMs that have high temperature solder connections.
Another issue was the fuel pressure regulator springs. The original springs would get weak over time and the engine would loose power. The springs on my truck broke and the truck would randomly quit when cruising down the road. The spring is located at the top of the engine near or on the fuel filter canister and is fairly easy to change. Unfortunately the knot heads at the local Ford dealer decided I needed my Turbocharger cleaned and charged me $1300 in addition to the $80 for the spring. I told them it was a fuel pressure issue, but they went ahead and cleaned the turbo anyway. That's the last time I'll ever do business with them because that was the third time in a row they did unauthorized work on my truck and charged me for it.
Ford purchased some of the earlier trucks back from consumers due to the extensive recall issues.
Ford no longer purchases engines from Navistar. They build their own and they use a different design.
Yes you have covered off some of the issues; unfortunately there are more.
You can likely expect to put a set of injectors in your truck in the fairly near future depending on how long it ran with low fuel pressure because that kills them along with oil system problems, over voltage from FICM, etc.
Most of the 6.0 problems were related to the emissions equipment and not from the factory tuning.
The coolant side of the EGR cooler doesn't get clogged, but the Oil Cooler does and starves the EGR cooler coolant causing the EGR to rupture.
Cracked pistons or bent connecting rods are very very rare failures. Coolant leaks in the combustion chamber typically causes head gasket failures it if problem is ignored.
I agree with the fuel pressure spring as a source of injector failures. 05 and up have very few injector failures.
Cold running issues were addressed by a inductive heating strategy that used the injector coil to heat the oil inside the injector. The root cause was a valve in the injector would exhibit bore polishing and create stiction. Many injectors are corrected by the inductive heat or a oil additive with boron as a friction additive.
The Ford dealer tech cleaning the turbo and charging $1,300 is a good example of Navistar and Fords debacle. Navistar reported that they were getting billed by Ford for misdiagnosed repairs just like mabynack did. The launch of the 6.0 was poorly implemented due to lack of tech training. Many techs were throwing parts at these engines causing major financial friction.
My experience with my 6.0 was actually really good. Seven years and 170k miles that truck cost me only maintenance items. Speaking of maintenance many problems were created from after market oil filers that allowed non filter oil to bypass the filter or the filter would completely fail and clog the entire high pressure oil system. After market fuel filters didn't have the aqua block media and would pass water to the injectors causing failures. Sticking to high quality Motorcraft filers prevented these issues.
44,056 PostsLatest Activity: May 04, 2014
