ScottG's avatar
ScottG
Nomad
Feb 06, 2020
2005 F150 tow rating
My neighbor and I are going to the Seattle RV show tomorrow. He is mildly interested in getting his first RV in the near future, perhaps a tent trailer. Naturally, I'm trying to set the hook..
It looks like his truck is rated between #7300 and #9300 depending on what what gearing he has. Is there an easy way to determine what diff he has?
Thanks,
Scott
  • Thx Ben. Yeah, I know we could figure it out but I was hoping the actual number is posted someplace, like it is on Ram's.
    The truck is bone stock and doesn't have a ton of miles. I think we can safely assume it's orig.
  • Used, so the previous owner(s) may have changed out the diff gearset
    Best and easiest is to tie a length of string to the U-Joint. Choose the one pointing straight down and roll the vehicle until it is pointing straight down
    Roll the vehicle one tire rev. Use the valve stem as a marker
    Then count the whole number of string turns. That will the the whole number...3 turns means 3.4 or 3.7...4 turns means 4.1, etc
    Then the fraction of a turn will be the rest of the diff ratio
    Remove the string (have to say this, as assumed they would in past posts and got some PMs yelling at me that I should have said that)
