- westendExplorerThe breakers are sized to protect the wire and still handle the current. I would guess 30 amps would work.
- BroncoRNExplorerAnd yes my circuit breakers look like the one in that link.
- BroncoRNExplorerSo putting a 40amp in there would be bad I take it.
- SUKISHORTExplorerThey are 30 amp get a couple of spares.
- WayneAt63044ExplorerPerhaps one is the tongue jack and the other is the 12 volt feed to charge the battery from the tow vehicle. I suggest you trace where the wires go and then you can determine the amperage. If your trailer is not too old the manufacturer should be able to advise you.
44,043 PostsLatest Activity: Jul 20, 2025
