wildwood333's avatar
wildwood333
2005 Lance 1191, battery modification to two Trojan T105,
I have used Lifeline AGM 12V batteries in the past. I intend to change over to two 6V Trojan T105 Golf cart batteries. I would like to use the existing Battery compartment with the sliding shelf. However, the Trojan T105 dimensions as stated on their web site is 7.11" wide, and the Lance battery shelf is 14". I have read in some of the posts out here that two Trojans will fit as they are the same as the 24. I understand the 24 is less that 6.75" Does anyone have experience with this issue? In addition: Is there any issues or adjustments needed to the existing charging system? Thank you
  • To get them to fit, you will need to remove the sliding tray, as I understand they are too tall to easily fit within the existing compartment. But there are no changes needed to the cables that were used to previously attach your OEM batteries.
    b
    no
